Goal: $300, Received: $215.00 (72%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2339 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    Registered user.
    Jan 2011
    Charlotte, NC
    39
    Default Korean Necor clock?
    I have just purchased an old 31-day clock. On the face it says "Necor" (below the 12) and "31 Day" (above the 6). On the back it says "Made in Korea". Upon removing the dial, I find stamped on the movement's left "leg": "Made in Korea" and "No Jewel". On the right leg it says, "SEHWA". Below the 6 on the dial, in small print, it says, "Made in Korea".
    The pendulum is supposed to hang from a short spring. Apparently that broke, and the guys who had it before (grounds keepers for a golf course) decided to try to fix it. They used some wire like a chain link to hang the pendulum from the spring. Of course that didn't work. So they applied grease to the springs. Still didn't work, so they just left it. I bought it for $30.
    Where might I find a spring like this? I can't even find information about this clock online so far. Pictures can be found at (warning: they're big!):
    http://www.llantup.com/2011-03-10-necor-clock-1.jpg
    http://www.llantup.com/2011-03-10-closeup-leg-1.jpg
    http://www.llantup.com/2011-03-10-closeup-leg-2.jpg
    http://www.llantup.com/2011-03-10-cl...m-spring-1.jpg
    http://www.llantup.com/2011-03-10-cl...m-spring-2.jpg
    http://www.llantup.com/2011-03-10-cl...m-spring-3.jpg
    Nov 2002
    39,808
    Default Re: Korean Necor clock? (By: sappha58)
    Hi, sappha58, welcome to the message board. Timesavers carries three sizes of Korean suspension springs. Measure yours and order the closest one.
    www.timesavers.com
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Registered user.
    Jan 2011
    Charlotte, NC
    39
    Default Re: Korean Necor clock? (By: harold bain)
    That was quick, and helpful! Thanks, Harold - I found the three rods apparently for Hermle style clocks. They look the most like the rod I have, anyway.
    Any idea how old this clock might be, or its worth?
    Thanks again for your help!
    Rebecca
    Quote Originally Posted by harold bain View Post
    www.timesavers.com
    Nov 2002
    39,808
    Can't help you with value, as it's against message board rules. The suspensions listed for Korean movements would likely be a better fit for this clock than the Hermle ones. As for age, 1970's or 80's likely.
    Registered user.
    Jan 2011
    Charlotte, NC
    39
    Sorry; I'll have to go back and read the rules again.
    I did order the suspension for the Korean movement.
    Thanks again!
  6. #6
    Registered user.
    Jan 2011
    Charlotte, NC
    39
    I just wanted to touch base back on this thread. After getting the new suspension spring as you suggested, the clock is keeping time like nobody's business! It took me a week to dial-in, but it runs beautifully. Thanks again for your help!
  1. Pendulum amplitude, Korean Weight clock
    By 0163964 in forum Clock Repair
    Last Post: 08-09-2011, 11:40 PM
  2. Korean calendar clock,double dial
    By Bruce Barnes in forum Your Newest Clock Acquisition
    Last Post: 04-17-2011, 07:15 AM
  3. German Necor Clocks
    By mwillard in forum Clocks General.
    Last Post: 01-10-2008, 04:58 PM
  4. 15 day korean wall clock
    By Kevin W. in forum Clocks General.
    Last Post: 01-21-2007, 12:30 PM
  5. Korean movement clock keeps striking
    By 107WestStreet in forum Clock Repair
    Last Post: 05-27-2006, 04:28 AM
