Goal: $300, Received: $280.00 (94%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2628 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Default Synchron Model 610 I43R motor repair/replacement
    I have a Synchron Model 610 I43R clock motor from a 1950's Lackner advertising clock that is not working. I've taken the motor apart as far as I know how, to where I can lift the pinion shaft/gear and magnet disc out of the motor. Everything looks clean, and the pinion spins smoothly, but it still doesn't work. Anyone have suggestions on repair? I've found a few replacements at $80 but was hoping to avoid the cost.
    This is the second non-working clock motor that I've been dealing with today. I'm going to submit a separate post for the other one (an Ingraham Model 17 from a 1950's PAM clock).
    Default Re: Synchron Model 610 I43R motor repair/replacement (By: bakerb95619)
    $80 for what from where? The motor you described is ±$26 + shipping from many sources - Pic from Timesavers site, is this it? For the "C" mech, rectangle shape. If the mech is just a bit larger then the motor footprint, this is not the motor for that mech, NLA new.
    http://www.clock-keys.com/CART/images/18404.JPG
    Timesavers site:
    http://www.clock-parts.com/catalogma...ID=211&Level=4
    Best - CW
    Default Re: Synchron Model 610 I43R motor repair/replacement (By: coldwar)
    Hello, That looks like the motor I need. The Timesavers site shows various gear sets for the motor, but they don't list mine which is a C5 Rear set. I don't need the gear set, but I want to make sure it's the correct motor for my gear set. I'm fairly certain it is. Thanks for the reply, Bill
    Nov 2002
    39,025
    If you don't need the whole movement, the motors are all the same on these. The gear set is only referring to the movement. But, as you see the movement with motor isn't much more than just the motor.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Can someone tell me when Synchron went out of business...if it did.
    Could not find it in the archives. Thanks, Fred
  6. #6
    Default Re: Synchron Model 610 I43R motor repair/replacement (By: Frederick)
    Still in business, thriving we hope:
    http://www.hansen-motor.com/about-us.php
    EDIT: I was delighted when viewing their clock mechs page to see the "D" mech in production. I thought it was out, perhaps it was, but there it is. Hopefully the motor will fit the older "D" style as well. I bought some from Howard Miller when they were drying up, supply now exhausted. Great!
    Best - CW
  7. #7
    Nov 2002
    39,025
    Coldwar, good to see they are still around. They were and still are movement suppliers to both IBM and Simplex for their synchron motor slave clocks.
  1. Ingraham Model 17 clock motor repair/replacement
    By bakerb95619 in forum Electric Horology
    Last Post: 01-05-2013, 03:38 AM
  2. Question about motor "SYNCHRON Model 610"
    By ooman in forum Electric Horology
    Last Post: 05-09-2010, 12:03 PM
  3. Synchron Model 610 I43R motor repair/replacement
    By bakerb95619 in forum Clock Repair
    Last Post: 01-02-2010, 10:59 PM
  4. Ingraham Model 17 clock motor repair/replacement
    Last Post: 01-02-2010, 10:54 PM
  5. Waltham 16S 1899 Model 610 grade 7 jewel OF Repair?
    By richard mortlock in forum American Pocket Watches
    Last Post: 07-15-2007, 02:49 PM
