Goal: $300, Received: $215.00 (72%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2353 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 30
    Registered user. Shogun's Avatar
    Dec 2009
    Texas
    107
    Default Crocus Cloth....6000 grit???
    Hello all!
    First off...HAPPY NEW YEAR...ALMOST!
    So my quest for 6000 grit Crocus cloth is becoming a bit tiring....does anyone know where I may purchase some?
    Thank-you,
    Shogun
    Apr 2004
    Mesquite, TX
    938
    Default Re: Crocus Cloth....6000 grit??? (By: Shogun)
    Six THOUSAND? Thousand? 'ell; Use newspaper!
    I find crocus cloth at the hardware store. It never has a grit number associated with it, just "fine" marked on the back.
    Default Re: Crocus Cloth....6000 grit??? (By: Scottie-TX)
    Crocus cloth is, in most cases, iron oxide abrasive and about 1200 grit. I don't know about it being available in 6000. If you need something that fine, you might have to try 'Micro-Mesh', a silicon carbide, cloth backed, wet and dry material in sheets. Other super fine abrasives are available from Rio Grande (jewelry supplies).
    Apr 2004
    Mesquite, TX
    938
    Default Re: Crocus Cloth....6000 grit??? (By: Jeff Salmon)
    Jes' curious (obviously): What're ya gonna do with this six THOUSAND?
  6. #6
    I just looked in the workshop as I knew I had bought some Crocus grade paper from Meadows & Passmore its part number is 0402 000115 and it says it is 2000 grit it also states it is from 3m 401Q imperial wetordry(sic) 2000, It feels soft to the touch I can not imagine needing finer paper.
    Steve
  7. #7
    Default Re: Crocus Cloth....6000 grit??? (By: AJSBSA)
    Try this place.
    bangster
  8. #8
    Registered user. hoo-boy's Avatar
    Nov 2008
    1/2 mile past Resume Speed
    412
    Default Re: Crocus Cloth....6000 grit??? (By: bangster)
    3m Corporation is leading maker of crocus cloth, google as they list the locations that sell their products State by State . fyi Crocu has been around for years and years it the ultimate in emory polishing Used in lotsa applications where a high degree of final finishing, polishing is needed or desired, Jewlery making, surgical instruments gunsmithing etc. I thought everyone knew what crocus cloth was . Silly me! ...hoo-boy
  9. #9
    Registered Users
    Sep 2006
    metro NY area
    3,951
    Quote Originally Posted by bangster View Post
    Try this place.
    bangster
    Here's one more: http://www.ottofrei.com/store/product.php?productid=4018
  10. #10
    Default Re: Crocus Cloth....6000 grit??? (By: Thyme)
    I bought mine on ebay. 4000, 6000, 8000, 12000 grit. It's called cushioned abrasive, Micromesh , micro surface finishing.... They were 6" x 3" sheets. One of each, 4 sheets total was around $15-18 or so, if memory serves me right.
    I just looked on ebay and can't seem to find it.
    It looks like it came from here...
    http://www.micro-surface.com/
    Ralph
  11. #11
    Apr 2002
    20,126
    Blog Entries
    Default Re: Crocus Cloth....6000 grit??? (By: Ralph)
    Lee Valley sells a similar product, i like it for polishing clock pivots.
    http://www.leevalley.com/wood/page.a...04&cat=1,43072
  12. #12
    Default Re: Crocus Cloth....6000 grit??? (By: Kevin W.)
    The use for crocus cloth, or other 6000 grit paper we're talking about here is pivot polishing, right? Are there other uses in clock repair? When the cloth is purchased in sheets what do you mount it on and how do you make it stick to whatever that is?
    Thanks.
  13. #13
    Apr 2002
    20,126
    Blog Entries
    Default Re: Crocus Cloth....6000 grit??? (By: JST)
    I mount mine on popsicle sticks and the stuff from LV has adeshive on the back of it.
    I use it only for pivots.
  14. #14
    Registered User Sooth's Avatar
    Feb 2005
    Cornwall, Ontario, Canada
    3,620
    Why do you need a paper that is so fine. I can generally get a mirror-like polish with 2000 grit (available in the automotive section), followed by rouge or Brasso as a polish.
    Failing this, I'm (fairly) sure you can get it from specialized clock parts dealers such as H & W Perrin in Toronto.
  15. #15
    Registered Users
    Sep 2006
    metro NY area
    3,951
    Quote Originally Posted by Scottie-TX View Post
    (I know Scottie has a sense of humor... and he has the power of censure here. )
    (Ahem.) Here goes nothin'...
    Sooper-Dooper toilet paper!!!
  1. Diamontene (diamond grit/powder)
    By RJSoftware in forum Watch Repair
    Last Post: 05-05-2011, 09:07 AM
  2. Seeking replacement side panel cloth for Colonial grandfather
    By jimmyd in forum Clock Case Restoration and Repair.
    Last Post: 06-05-2010, 01:57 AM
  3. Cloth for back cover
    By BIG D in forum Clock Repair
    Last Post: 10-12-2004, 11:52 PM
  4. Old Cloth Electrical Cord
    By craig in forum Clock Repair
    Last Post: 04-16-2004, 03:25 PM
  5. Old Watch Dial Pins to wear on clothes?
    By Jon Hanson in forum American Pocket Watches
    Last Post: 02-09-2004, 09:56 PM
