Goal: $300, Received: $280.00 (94%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2897 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
    Registered user.
    Sep 2008
    Maryland
    769
    Default What does "unadjusted" mean on a clock or a watch?
    I often found the word "Unadjusted" on the clock or watch movement.
    I have no idea what it means. Any informatin will be highly appreciated.
    Ming
    Registered User lesbradley's Avatar
    Dec 2007
    Fairford, England
    1,017
    Default Re: What does "unadjusted" mean on a clock or a watch? (By: marylander)
    "Adjusted" and "unadjusted" are more watchmaking terms than clock terms. "Adjustments" are complicated processes to make a watch keep time at the same rate in 1)different temperatures, 2) "isochronism", when the watch is fully wound versus nearly unwound, and 3)"positional", when the watch is in different positions, such as face up, face down, etc.
    In clocks, positional error is not, of course, an issue. Isochronism is the only issue for mainspring-driven clocks, as weight driven clocks supply even power at all times. Temperature compensation is an issue for all mechanical clocks, and is remedied on anniversary clocks by the stability of the suspension spring.
    I suspect that the marking on 400 day movements is either traditional or related to import/export laws, and has little practical meaning.
    Les Bradley
    Registered user.
    Sep 2008
    Maryland
    769
    Default Re: What does "unadjusted" mean on a clock or a watch? (By: lesbradley)
    Les, Thank you very much. It is clear.
    Ming
    It is my understanding that the US had import duties that were much higher on horological items if they were "adjusted" and even though many watches were in fact "adjusted" to positions they were marked "unadjusted" to avoid the extra import tax.
    Registered user. Ingulphus's Avatar
    May 2006
    Oakland, CA
    702
    Default Re: What does "unadjusted" mean on a clock or a watch? (By: jkfabulos)
    I believe that's why they marked movements as "No (0) jewels" as well - even ones that you wouldn't expect to be jeweled, such as 400 day clocks.
  1. What does "AD.N." stand for as a clock maker/seller?
    By Spaceman Spiff in forum Clocks General.
    Last Post: 12-01-2013, 09:43 PM
  2. Leaving your mark on a clock, or not?
    By R. Croswell in forum Clock Repair
    Last Post: 07-31-2008, 12:41 AM
  3. Replies: 14
    Last Post: 04-01-2006, 12:16 PM
  4. Military Watch... what does w w w mean?
    By ronion in forum Wrist Watches
    Last Post: 12-16-2003, 05:49 AM
  5. What does the railroad grade mean?
    By in forum Horological Misc
    Last Post: 12-03-2002, 03:04 PM
