Goal: $300, Received: $280.00 (94%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3627 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
    DADSTIMESHOP
    Guest
    Default How to tell from Gold Plate, Gold filled or Solid Gold??
    I know the markings on the inside lid I can look up.. but there are so many.. How do you no which is which.. and how can you tell if you have a Gold Filled or a solid gold case.. Also how can you tell if the case you have that is gold filled or Rolled gold which Karat it is? Also I always see the serial numbers on the inside lid? where do you look that number up.. is there an online data base.. like for the movements? I was thinking of buying a gold tester.. would this be wise? or are all cases usally the same??
    James
    Dec 2001
    New Hampshire
    4,876
    Default Re: How to tell from Gold Plate, Gold filled or Solid Gold?? (By: DADSTIMESHOP)
    Generally if there is a warrantee period it is gold filled. This apples even it the warrantee is permanent. If it is solid precious metal it will usually say Guaranteed US Assay. For lower than 14 carat it will say this even when it does not say gold. I don;t know of US plated cases but European ones will have a number followed by "microns". A micron is a thousandth of a millimeter and is the estimated thickness of the plating.
    So far I know of no data base for case serial numbers. I know at least one US case maker who often put serial numbers on the case to match the movement.
    My experience is that marks are relaible. I have never used a tester but the people I know have a lot of skill in this. It is not easy and it of use mostly for unmarked items like watch chains.
    For cases, it is usually possible to tell by feel.
    [edit=474=1176374445]addition[/edit]
    The only way that I am aware of to tell by feel if a case is solid gold or gold filled is to hold two comparable cases ( one gold filled and the other solid gold) for a few minutes in your hand to warm them up. After you put them on table for minute or two the one that cools off quicker is gold filled.
    James
    Unless you know what you are doing, testing a case can leave undesiriable damage.
    ,Shugurts Price Guide has pictures of many of the symbols used for solid gold and gold filled. Periodically this Board has discussed this issue and possibly someone can find an old thread.
    With Hampden watches whether the anchor used as part of their symbol is raised or not can be an indicator of gold filled vs solid gold. That being said they are many exceptions. Also Hampden cases that are marked Special are gold filled and for later Howard watches J Boss cases are gold filled.
    By becoming knowledgable you can protect yourself.
    Bob
    Aug 2000
    Boston, Ma.
    17,580
    Blog Entries
    No, gold has a special "feel" to it, plus the bend/rigid factor
    I agree wth Jon. After you handle enough of these cases you can tell solid gold by the feel of it.
    Tom
  6. #6
    What Jon and Tom said.
    Don
  7. #7
    No matter how you hold it, look at it or whatever, nothing gets by the ACID TEST. It is a simple process that every jeweler uses to confirm the ct of very rare or expensive items. It is a very simple test and done right (use the sharp edge of the cover on the FINE stone that comes with any acid test kit ) NEVER NEVER put the acid on ant part of the watch. Dnoe propoerly no damage or evidence of the test can be detected. Many PW's are marked 14K 18K and are nothing more than heavy gold plate I test every PW if in doubt.
    Ron
    [edit=5976=1176493835][/edit]
  8. #8
    Aug 2000
    Boston, Ma.
    17,580
    Blog Entries
    and many a fine case has been ruined by the acid test and/or filing a groove to check for the cases content!
  9. #9
    The slate - acid test will give you the gold content of the surface material, but not the interior (unless you damage to the case). In this test, the case is rubbed over a piece of slate leaving a small amount of gold behind. This is treated with nitric acid and timed to see how long it takes to dissolve. If it does not dissolve, it is tested with aqua regia and timed. This time is compared with standard gold samples that come with the kit.
    Great damage is done when people file into the interior to see if the gold goes all the way through. There is no excuse or need for this.
    Ron is correct for the surface.
    Jon is correct for the interior.
    Don
  10. #10
    Technical Admin Tom McIntyre's Avatar
    Aug 2000
    Boston. MA USA
    18,620
    Blog Entries
    10
    I would think that the impedance gold testers should work, in principle. I have no experience with them. Does anyone know how well they work?
    You should be able to measure the acoustic impedance also to get information, but it would take a bit of development to get a consistent set of values for calibration.
    Tom McIntyre Click me.
    If you don't learn to laugh at trouble,
    you won't have anything to laugh at when you're old.
    Will Rogers
  11. #11
    Aug 2000
    Boston, Ma.
    17,580
    Blog Entries
    Quote Originally Posted by Don
    Don
    Intereior--heck, I have seen many a GF blazer case filed on the outside!
  12. #12
    You Betcha!!!
    Or the tell tale 'spots' on the inside of the back, or curvette......
    EVEN WHEN MARKED GOLD FILLED
    Chapter 17 North Carolina
    http://www.nawcc-carolina17.org/default.htm
    Chapter 149 Early American Watch Club .. Home of Russ Snyder Illinois CD database and Henry Burgell Serial number Look-up ... excellent research resources!
    http://www.nawcc-ch149.com/ http://www.nawcc-ch149.com/pw_dbresearch.html
    Chapter 149 Mentor List http://www.nawcc-ch149.com/mentor.html
  13. #13
    Aug 2000
    Boston, Ma.
    17,580
    Blog Entries
    a total disregard for these wonderful objects .
    I have seen huge acid marks in plain view (inside, outside), file marks or cuts with a knife everywhere--so, if gold they got scrapped; if not gold they care less! ......................Just another day in the life of a scrapper!
  14. #14
    DADSTIMESHOP
    Guest
    Holy smokes I would never want to scrape on any of my watches!! I was thinking more about the electronic ones.. and also the color does that have something to do with it... may I should just post them up here when I can't figure them out.. you guys do a lot better than. me...
    Thanks for all the wonderful knowledge you guys have!!!
  15. #15
    I am sorry to all the watchmakers out there but I am very disapointed that they took it upon themselves to mark up the inside of watches. I have a couple that are defaced by the scratching performed on them.
    Sorry but thats my beef and I am sticking to it .
    [edit=5965=1176921335][/edit]
    [edit=5965=1176921342][/edit]
  1. Single weight Viennas; how to tell 7 day from 31 day?
    By Chris in forum Clocks General.
    Last Post: 07-08-2012, 08:45 AM
  2. how to tell if a gold color case is gold filled or not(no marks)?
    By dodothree in forum American Pocket Watches
    Last Post: 01-27-2012, 02:36 AM
  3. Gold-Filled or Solid Gold?
    By Ethan Lipsig in forum American Pocket Watches
    Last Post: 02-15-2011, 10:10 AM
  4. book review:how to tell time
    By wcrawforth in forum Horological Books
    Last Post: 01-08-2007, 01:33 PM
  5. How to tell Real Rolex from Fake Rolex
    By Jeff Hess in forum Wrist Watches
    Last Post: 04-23-2004, 05:56 AM
Members who have read this thread: 5
