NOTICE Notice: This is an old thread. The last post was 4186 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 11 of 11
    Default Hermle time adjustment
    Hi,
    I have a tradition mantle clock with a Franz Hermle movement #340-020.
    I am new to this and would like to know how to advance the time since it losses 5 minutes every few days.
    It has a + and - on the top of the movement but how do you adjust this as there seems to be nothing to turn.
    Thanks for your help.
    Default Hermle time adjustment (By: Term)
    Hi,
    Moderator leeinv66's Avatar
    Mar 2005
    Launceston Tasmania
    7,693
    Blog Entries
    Hi, does it have an adjustable nut under the pendulum bob? If yes, that is where you adjust it. If not, look for an adjustment where the suspension spring hands. Hope this helps!
    Cheers
    Peter
    Cheers
    Peter R Lee: AKA (Pee-Tah) from Australia
    No pendulum on this movement. What's a suspension spring?
    Sorry newbie.
    Mar 2005
    Launceston Tasmania
    7,693
    Blog Entries
    Sorry should have read all the post instead of skimming. Does you movement have a balance wheel? If so, there should be a lever that the hair spring loops through. This is what you adjust.
    Cheers
  6. #6
    Registered user.
    Mar 2004
    Memphis Area, TN, USA
    490
    I think this is one with a "balance Wheel". Look on top of the wheel that swings back and forth. there will be 3 prongs or feet. Slide the upper part in direction of + or - to speed up or slow down.
    Good luck, Don
  7. #7
    This movement has a floating balance. If you will look closely, you will that there is a ring with holes in it. On top of the ring is a thing with 3 arms that press down on the ring. Hold the ring stationary and move the arm of the other piece in the "+" direction.
    Moving it from all the way left to all the way right makes about 3 min per day difference. So... you should use small adjustments... say 1/4 in.
    Don't get rough with it... it is not super delicate,but it can break.
    David
    David Robertson - Kingsland, TX
  8. #8
    Thanks,
    I believe I read your instructions right, I moved what you said and I hope that works, let you know in 24 hours.
    By the way great board. Quick response and great advice, look foward to learning more as I get more clocks.
  9. #9
    I have adjust te wheel as far as it will go towards the plus side and still loss about 2 minutes a day. Is this normal, if not what are my options now?
  10. #10
    Nov 2002
    39,628
    Term, your clock needs service. How far do you want to go yourself? You can get a new movement identicle to the original for this clock for a reasonable price.
    Harold
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  11. #11
    Registered user. bchaps's Avatar
    Dec 2001
    Mountain Top, PA
    1,123
    Term...I think Harold is correct. I have a carriage clock with the same movement. It's now losing 15 minutes per week. It needs to be cleaned and lubricated. Since this is a three-train movement (Time, Strike and Chime), this is not the movement to begin your clock repair adventure. If you have an interest in clock repair, buy an old time only clock with a decent movement such as Seth Thomas and start your adventure at that level. There are lots of good books to help a beginner and this board will come to your rescue when you're stuck. (been there many times). Best Wishes, Bill
    Bill...
    Member Chapter 1
  1. Schatz anniversary clock timing adjustment
    By dadofern in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 01-14-2007, 10:34 AM
  2. Hermle self adjusting clutch assembly
    By Mwerner710 in forum Clock Repair
    Last Post: 11-07-2006, 08:11 AM
  3. Kroeber time adjustment
    By Paul FM TX in forum Clock Repair
    Last Post: 04-29-2004, 10:42 PM
  4. Gilbert Time Adjust Gear
    By Ed Jones in forum Clock Repair
    Last Post: 01-04-2004, 03:39 AM
  5. Schatz time adjustment
    By Mikes in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 12-26-2003, 12:46 AM
